CreativeMarket - 140 Image enhancing gradients
GRD, PNG
Requirements: Adobe CS1+1.09
Mb 140
Gradients for your daily use. These are really good for images, for enhancing them, for adding them a bit of style. However, you can use them for other purposes as well. The showcase image was enhanced with the help of these gradients. You can do a lot of things and styles, it depends on the way you are experimenting with them.
