GrарhiсRivеr - Typography 2 Photoshop Action
Layered PSD, Photoshop ATN | Works With PSD | Minimum Adobe CS Version: CS3 | 5.62 Mb
Create this highly detailed, advanced looking effect from your photos with no work at all. After you play the action You got full text control, you can place your own text, change font size, font style, line height and much more!
The action is tested and working in Photoshop (English versions) CS3, CS4, CS5, CS6, CC.
The action is only working in English versions of Photoshop. If you are using another language, you can easy change it to English in this way.
After you play the action, you can change it back to your native language.
If you need any help with the action or you got any questions, please contact me via my Envato profile page.
Combine actions If you have more than one my action, you can combine the effects an build even more advanced designs.
Below there are over 20 actions to choose from.
How do I combine actions?
1) Run the first action on your photo.
2) When you finish with customizing the design, save your image.
3) Now re-open your image and run another action! You can then use the 2nd actions layer flexibility to further customize the design. In this way you can build incredibly detailed, advanced designs with no work at all.
