Содержание архивов (архивы независимы):
Архив 1
2007-01-05 - Distorted 3D Grid
2007-01-12 - Warped Mist
2007-01-26 - Ring of Fire
2007-02-02 - Lighting on Multiple Surfaces
2007-02-16 - Abstraction
2007-02-23 - Graphic Texture
2007-03-06 - Extreme Edges
2007-03-12 - Degrees of Masking
2007-03-19 - Reflections Revisited
Архив 2
2007-03-26 - Need For Speed
2007-04-03 - Highlight Blowout
2007-04-10 - Custom Text Brushes
2007-04-16 - Graphic on Mug
2007-04-24 - Follow The Evidence
2007-05-01 - Shooting Star
2007-05-07 - Sunset Silhouette
2007-06-19 - Multi Box Design
Архив 3
2007-05-14 - Got a Light
2007-05-22 - Create Background
2007-05-29 - Masking with Channels
2007-06-05 - Quick Makeover
2007-06-12 - Type with Texture
2007-06-29 - Scatter Brush Masking
2007-07-11 - Line Drawing to Photo
Архив 4
2007-07-19 - Painting Motion
2007-08-01 - Add Pizazz
2007-08-01 - Energetic Burst
2007-08-20 - The Power of Layer Styles
2007-09-19 - Design With Alpha Channel
2007-10-12 - Vanishing Point
Архив 5
2007-10-24 - Pattern Maker
2007-11-09 - Animated Transitions
2007-11-30 - Beads of Sweat Effect
2008-01-04 - Remove Noise
2008-01-18 - Photo to Drawing
Архив 6
2007-12-19 - The Davinci Design
2008-01-29 - Folds and creases
2008-02-08 - Dramatic Color Effects
2008-02-28 - Animated Rain
Архив 7
2008-03-07 - Design With Grids
2008-03-14 - Animating Color Transitions
2008-04-11 - Borders Under a Minute
2008-04-18 - Custom Coins
Архив 8
2008-03-28 - Text Shape Layers
2008-04-25 - Natural Brushes
Автор: Corey Barker
Формат: flv
Количество: 45
