Pro JavaScript Design Patterns Год выпуска: 2008 Автор: Ross Harmes, Dustin Diaz Издательство: Apress ISBN: 1430204958, 9781430204954, 159059908X, 9781590599082 Формат: PDF Качество: eBook (изначально компьютерное) Количество страниц: 269 Язык: Английский Описание: As a web developer, you ll already know that JavaScript is a powerful language, allowing you to add an impressive array of dynamic functionality to otherwise static web sites. But there is more power waiting to be unlocked - JavaScript is capable of full object–oriented capabilities, and by applying OOP principles, best practices, and design patterns to your code, you can make it more powerful, more efficient, and easier to work with alone or as part of a team. With Pro JavaScript Design Patterns , you ll start with the basics of object–oriented programming in JavaScript applicable to design patterns, including making JavaScript more expressive, inheritance, encapsulation, information hiding, and more. With that covered, you can kick–start your JavaScript development in the second part of the book, where you ll find detail on how to implement and take advantage of several design patterns in JavaScript, including composites, decorators, facades, adapters, and many more. Each chapter is packed with real–world examples of how the design patterns are best used and expert advice on writing better code, as well as what to watch out for. Along the way you ll discover how to create your own libraries and APIs for even more efficient coding. - Master the basics of object–oriented programming in JavaScript, as they apply to design patterns. - Apply design patterns to your kick–start your JavaScript development. - Work through several real–world examples. What you ll learn: - How to apply object–oriented programming techniques in JavaScript - How to take advantage of inheritance, interfaces, and encapsulation and information hiding to kick–start your JavaScript development - How to implement several design patterns in your JavaScript projects, including factory, facade, bridge, composite, adapter, decorator, flyweight, proxy, command, observer, and chain of responsibility - How to make your code easier to manage in a team environment, as well as on your own - How to create your own libraries and APIs Who is this book for? This book will be an invaluable learning tool for any experienced JavaScript developer.
